Rear suspension
Today I learned that my coil springs over the leaves in my 1960 are not a stock item.
I am getting beat down like Rocky Balboa when I drive this thing down the road. I thought... heh, old truck. How soft is the rear on a stock suspension if I pull those out and leave the leaf springs and shocks? |
How many leafs are in the rear spring pack, seven or nine? If less, someone either removed leafs from the pack or installed 1965/67 F100 5 or 6 leaf rear springs (a bolt on replacement).
Coilovers were available at the parts counter. If the shocks are marked Rotunda (as original), Auto-Lite or Motorcraft (service part replacements), they are genuine Ford parts. Coilovers (usually Monroe's) were also available from autoparts stores, spring and front end shops, RV dealers. |
9 leafs, a set of coils over the axle and shocks in the normal 1960 spot
I'd pull them and see how it rides. How do you intend to use your truck?
