Slower to start after oil change
I just changed my oil, filter and fuel filters. I have noticed that it takes alittle longer to crank when its cold. It runs fine and starts fine after it warms up. I used rotella 15W-40. It has the ford oil cap on it. No fuel leaks or anything... But it does seem to take alittle longer to start maybe 4 seconds of cranking or so... It was about 2 seconds.... Just curious any ideas?
Daniel |
Injector issues are starting to show.
Originally Posted by Roasted7
(Post 11664480)
Did you use the MC FL-2016 Oil Filter ? From what I have Been told,,,this is the ONLY Filter that should be used on a 6.0 !!
Other filters are Inferior to MotorCraft, different dimensions etc,,can cause issues with the 6.0 !!! |
Originally Posted by m350
(Post 11669685)
Other filters are Inferior to MotorCraft, different dimensions etc,,can cause issues with the 6.0 !!! Ford: 3C3Z-6731-AA Racor: FL-2016 Navistar: 1840752C91 Fram: CH9549 All four of those part numbers are the exact same filter made by the same company (Racor) and only the packaging is different. Well, and the price is the other difference. |
