05 expy EB harsh suspension!
I though I would give Detroit's cars another chance, but so far I'm not liking it. My 05 EB expy's ride is much harsher than my 04 4runner! What is up with that?
I would like to explore another suspension setup rather than OEM. If anyone knows of a good replacement source please let me know. BTW, this car has only 47K miles on her. TIA. |
Are you sure your suspension is OEM? If you didn't buy it new, I would suspect it is not, as the Expedition is one of the most softly-sprung vehicles I've ever ridden in. My '03 XLT 4x4 rode like a sofa on wheels until I swapped out the OEM shocks with Bilstein HDs to firm up the ride a bit. Let up know if your suspension includes any after-market equipment...
It's all original OEM, I crawled under there today saw the struts and the Ford emblem on them.
Could it be because it has a heavy duty towing package and therefore the suspension is much stiffer? Or could it be the tires? It has Firestone Destination A/T the pressure is set at 36PSI. I wish mine rides like a SOFA :) |
I agree with Abolt. My 03 rode like a dream, it started getting kind of bouncy towards the end but I just assumed it was time to replace the struts. Mine also had the tow package.
You could look into swapping in the optional factory air ride. But I must worn you it might be more trouble in the long run. Many people and up swapping over to coils due to componenent failures after higher miles. |
Originally Posted by AirLiftCompany
(Post 11600885)
You could look into swapping in the optional factory air ride. But I must worn you it might be more trouble in the long run. Many people and up swapping over to coils due to componenent failures after higher miles. And BTW, I hear you about air suspension, too much work for little gain and I agree, them airbags are big bucks and un-reliable. |
Another vote for the tires. Went from Michelin LTX M/S to BFG All Terrain TA on my 99 EB. Man did that truck feel harsh after the swap. The 05 has the LTX's on it now and I will be replacing them with the new M/S 2.
Originally Posted by Hongster
(Post 11600282)
