Got some good progress going on. How hard was it to press out those old front shackle bushings? Mine were held in there pretty good with rust. I pressed mine out just like you did the one was so tight even after heating it up some I broke one of the bolt hole ears off and had to weld it back on. Are you using a u bolt flip kit? I think you mentioned it before but what are those rear spring hangers out of? Are they for 3" springs? I need to get longer spring hangers to correct my pinion angle the SD hangers I have are to short making the axle locating pin tilt forward to much instead of pointing to the ground. Would you mind taking some measurements of them if I took pics of what parts of them I need measured? Every time I look at these cummins build threads makes me want to work on my crew but I keep having other things pop up to drag me away from it. And keep having to spending my axle funds on my new truck to fix all the little problems to keep it reliable
Originally Posted by crazed87bronco
(Post 12465569)
Can't you just relocate your spring perch on the axle to change your pinion angle? I have to get my transferase in before I can weld my spring perches in so that I know what the proper angle will be. The hangers are from the front of the rear spring on an '85 Chevy 4x4. They are for a 3" wide spring. By using a set of these (both the front and rear) on my rear spring (shackle flip assumed), I can get about 5" of lift in the rear without any spring adjustment. Since I am ditching my lift blocks, I will still have to use around a 5" lift spring to make up the difference. I am thinking about just ordering custom rear springs from Alcan since they are local here where I live. Let me know what specific measurements you want and I will post pics :-X10 |
2 Attachment(s)
Received the U-bolts and plates from Ruff Stuff the other day. Notice that one U-bolt is larger than the others. This is to make up for the U-bolt that has to go over the differential case a little bit. From what I understand, I am going to have to notch the differential housing gusset to flip the U-bolts and make these work.
Attachment 235287 I also have been working on additional gauge mounting locations in the cab. I ditched the stock stereo and shaved the stereo mounting bezel to accept a plate with 2" holes in it. I had to glue the plate to the bezel since the bezel is cast, but it looks like it is going to hold fine. Cleaned up the additional glue with a razor blade and some sand paper and painted everything up :-X04 Attachment 235288 |
5 Attachment(s)
Flipping the U-bolts on the Dana 60 is not so simple. My initial plan of attack was to drill a 5/8" hole in the gusset and try and slide the U-bolt in. This would have left some of the gusset intact and much stronger.
Attachment 235289 Since getting the U-bolt in like this was impossible, I decided to cut out the rest of the material with a port-o-band. Attachment 235290 Smoothed the edges a little for curvature and there you have it. I am planning on adding a 1/4" bridge on the gusset I had to cut to give it back some strength. I had to drill out the location hole the U-bolt plates to fit the bolt on the 1999-2004 Superduty springs. Attachment 235291 And there you have it :D Attachment 235292 Attachment 235293 |
This is awesome me and a friend are doing almost the same thing but ours is a crewcab. But thanks for all the awesome ideas. Keep up the great work
5 Attachment(s)
Time to mount the the rear front hanger. Since I am using 64" Chevy springs, I have to move the rear crossmember to match the new location of the hanger. If you don't do this, you will get unwanted flex in the frame and it could be an issue over time. Notice that the crossmember was located exactly in the location of the stock hanger. There is a reason.
Had to drill out the rivets to free up the crossmember - my favorite :-X13 My measurement from center of the bump stop to center of the spring hanger bolt was 31 1/2" since the spring I have as a reference is 63" eye to eye. Attachment 235294 The nice thing is that once the crossmember was free, the front hole lined up perfectly with on of the old rivet holes and I could put a bolt through to secure it. This kept everything square. Attachment 235295 Next I lined up the Chevy hanger, clamped it in place, and drilled out some bolt holes. I still need to plug weld all the other holes in the crossmember and weld the part of the hanger that goes on the bottom of the frame in place. Attachment 235296 The nice thing is that my hanger lined up perfectly so that I could use the large existing hole in the frame as a reference so that each side would be exactly the same. Attachment 235297 And there you have it. After a little welding, the front hangers for the rear are done. Attachment 235298 8D |
Your really moving along now almost got it as a roller. I went through the same exact thing with my front 44 when I put it in with the u bolt flip and and the center hole in the plate I also had to slot the one u bolt holes for the larger bolt around the pumpkin webbing I just notched the webbing so it sits up in there nice I wasn't sure if I'd have to do the same when I get my front 60 built good to know what I'll have to do now. I have the money to build my front axle but I'm debating buying a even bigger turbo for my other truck (one major reason I haven't been doing much with the crew lately) all my time money in that lately. But as for my rear hanger situation I could cut reweld the leaf perches to correct angle as ill be doing it anyway to get them perfect in line with the springs but the spring locating pin that gos in the perch is angled towards the front of the truck instead of straight at the ground so to correct it a longer front hanger will push the pin downwards more. What is the length from the bottom of the frame to center of the Chevy leaf mount bolt hole that gos through the leaf eye?
1 Attachment(s)
Got the Felpro gasket conversion set in the mail today :-X06
Attachment 235299 Goals for the week are to get the oil pan repaired, fab a new front axle mount for the passenger side, fab a new cross member to finish off the rear crossmembers, and ??? Mount the engine? I probably am getting too far ahead of myself. I think I will wait to do most of the gaskets in this kit including the killer dowel pin when the engine is mounted. We will have to see how things come together :-blah |
3 Attachment(s)
Here is your measurement Mr. Crazedbronco = 4"
Attachment 235300 I got a little more work done today. Got the rear crossmembers cut to the right length (33 7/16"). I used 3/16" steel 5" X 2". I will cut out the small factory angle iron piece once I get everything squared up and welded into place. Attachment 235301 Also got the passenger side axle perch fabricated. Just need to line everything up and tack it into place. Attachment 235302 |
2 Attachment(s)
Pulled the oil pan off of the cummins today to assess the damage. The good news is that the cummins oil pickup is built like a tank and undamaged. the bad news is that my oil pan isn't worth repairing :'(
Attachment 235303 Attachment 235304 On a happy note. Chasetruck shared a awesome link for info on the 1994-1998 Cummins fuel system: Joe G's fuel system writeup - Dodge Cummins Diesel Forum That is what I call comprehensive! |
Cool project. Wish I had done the cummins in my 75. It still has its 360. I live between Montrose and Delta, CO Drove by your way a couple weeks ago.
1 Attachment(s)
Might have missed what you decided to do about your fuel tank, but if not. Have you considered using aftermarket tool box/fuel tank in the bed? I have one on my F350 SD and it holds 40+ gallons plus a nice size tool box. Nice build thread too!!
Attachment 235305 |
Originally Posted by cowboyfordlord
(Post 12528314)
I head out to Grand Junction pretty regularly for parts and steel. Pacific Steel is the best. Next time you are in Moab on a Saturday you could drop by my church for some good old fashioned preaching :-X04
Originally Posted by itsnotanova
(Post 12536335)
Ordered the a new oil pan from Geno's Garage the other day. $140 delivered :-X15 Now I just have to wait to get that installed before I can build motor mounts. I have a broken passenger side motor mount. I am thinking about just building my own custom motor mounts and ditching the factory ones attached to the engine since a new motor mount is $100+. I need to get the engine hanging between the frame before I can know for sure. |
6 Attachment(s)
Sorry for the lack of progress guys :-X15 The grocery getter had a front passenger tire that tried to choose a different direction unexpectedly. Now I am stuck rebuilding the front suspension on the A to B car :-banghead
Attachment 235306 Attachment 235307 Attachment 235308 Remember that 1993 Turbo Diesel I got for $860? It got traded the other day for this ~ Attachment 235309 Pretty UGLY Right? Here is why I traded it ~ Attachment 235310 Attachment 235311 It's a 1979 F350 4X4 with Dana 60's front and rear. For now I will drive it around and smash it up a little bit. After I am done with the current project - it will be getting a nice doner body from a 2wd Truck and a 4" Lift. |
Nice trade, not so nice broken ball joint. Looks like it could have been a lot worse! I'm guessing you weren't going to fast when it happen?
