2wd Front Rotor Wheel Bearing Question
Hi, I searched this SD forum but could not find a direct answer to my question. I'm picking up new front rotors for my 03 F350 dually. If I clean and inspect the old wheel bearings and don't see any problems, can I reuse them or is it much better to buy new bearings? I know the old bearings are worn into the races in the old rotors, so do I risk problems effectively giving them new races to ride on?
Thanks in advance for your help. Steve |
With what you stated about the old races if it were me I would just buy new Bearings and not risk having problems.
I have been told in the past that wheel bearings and races are manufactured to be matched sets and that if you replace one you are supposed to replace the other. In fact when you put new bearings in you aren't supposed to mix up your new races and bearings and keep them matched up as as they were in the box. I don't know how accurate this is, but it makes sense to me. It actually brings up a question, can you even buy races by themselves? I always thought they were sold together and new rotor hubs came without races.
Go to Autozone and get some Timken Wheelbearings. I got some on mine and they're still turning nice and smooth. Matter of fact, I think they need some grease...
Originally Posted by Toreador_Diesel
(Post 11562357)
I don't have a superduty but the twin i beam system hasn't changed much from my truck to the super duty. I'd just get new bearings if your replacing the rotors. They are not much more price to add on. Also don't forget the seals either. My local napa store hooked me up with all the parts i needed.
Thanks guys. I finished this last night. I put in a full new set of Timkens from Napa and everything is back together. I did almost forget the cotter pin on one side, my wife pointed out that little pin laying on the towel while I was hammering on the dust cap. :-hair She earned her date night with that one!
The new rotors came with races pressed in. The new bearings also came with races - and yes, you can buy just races because the outters came in seperate boxes. I did not want to press out the races in the new rotors to put in the ones that came with the bearings. I've never done that before and I guess if that was a bad thing then why would they put new races in the rotors anyway? Incidentally, as I'm sure all of you have encountered, those brake caliper bracket bolts are really hard to get loose. Part of the issue is the rusted heads that required I hammer on the 13/16 socket, which then gets stuck and won't come back off. I used a 21MM 6 point socket instead, which still grips the head well enough but does not get lodged. That and a breaker bar and a 3 foot cheater pipe did the trick. Try that if you get stuck. |
Originally Posted by satwood
(Post 11569150)
2wd Super Duty front bearings-machine shop or me?
I got the rotors off my 2wd 2000 f250, can I put the new bearings in, or should I take it to a machine shop?
It's real easy to do yourself, just gently knock both of them out with a block of wood and you're good to go...
O'rielly auto even has a tool to pack the bearings before you put them in. |
(Post 11569150)
