What' the best scan tool ????
Hello to all, I was just wondering what is the best scan tool to buy that does it all !!!! I dont use it much so i dont want to spend a fortune. But i do want one that will tell me whats wrong when i need it too.....
Thanks... :-X22 |
One person's fortune, is another person's Dime.
Look into AutoEnginuity. Order Online With Ford bundle. Will do what you need. |
I bought an ELM bluetooth OBD sensor off of ebay, and downloaded the Torque app for my smartphone. I'm still figuring it out, but it only cost about $35 total.
Personally speaking, the best you can buy is an AutoEnginuity and the best price you'll find is RiffRaff:
Riffraff Diesel: AutoEnginuity Total Ford Enhanced Bundle Now if you want something that's simple and easy to transport around...ScanGauge II fits that bill nicely. I think they're going for $150-$160 at either AutoZone or on Amazon. |
Will the scangauge read enhanced codes like contribution?. All i can get out of mine is basic sensor codes.
Originally Posted by steelhead2
(Post 11563742)
I don't think I've ever heard any definitive answer on whether the Scangauge will read Enhanced Codes. I do know people have reported that it will list the number of codes (it will tell you there are 5 codes, for example), then read none or only a few of them. This suggests that it will only read generic ODB-II codes.
That's something that someone who owns one might be interested in checking with the manufacturer about. |
Ok what i was really looking for is a hand held device (not laptop). Ive got a basic code reader OBDII, I have a buddy whos truck cranks but wont start !! I just wanted a tool that would read all codes and tell me if it was the camshaft pos sensor or any other sensor. If that A E one is the only way to go then so be it.
Scangauge has numerous gauges available to check things.
It can be used for some diagnostics. Once a person learns what all the gauges need to read. Here is a list of most of the ones that can be programmed in the Xgauge area. Some of these have operating values. ( the ones in bold I have yet to see anyone get working) https://www.ford-trucks.com/forums/1...l#post10227382 $169 |
ScanGauge II does not really qualify for what I would call a scan tool. It's a great gauge set for the 6.0L but it only tells me there are 4 DTCs, it can't tell me what they are. AutoEnginuity does. To be fair, Autozone and O'Reilly scanners didn't find them either.
I think you need both, but if you have to choose then get the ScanGauge. You need full time monitoring of oil and coolant temps, and frequent checking of FICM volts, ICP and IPR, numerous other things. It should tell you active codes. You can clear codes with it. It's a good trip computer. The Edge Insight is prettier but costs a lot more, and doesn't do everything the ScanGauge does. |
Ok !! all sounds good but would the Scangauge tell me if it was the IPR valve screen causing a no start condition ???
Originally Posted by Bodger
(Post 11618580)
RiffRaff is the bomb! |
You can use it to see ICP and IPR values in real time. It won't tell you what part is bad but it lets you see many values from the various sensors and signals to various actuators so you can figure out what's happening. It does generic OBDII but it doesn't do much on the vehicle specific stuff so it's not a great choice for a code reader. AutoEnginuity is software for your laptop if I'm not mistaken.
Lots of suppliers like Snap-On, Mac, or Cornwell have several NICE code scanners to choose from but there are less expensive options on Amazon.com or your local parts store. Some key things to look for are "CAN compliant", "freeze frame data", and "real time data". A backlit 3 line display is also very nice. |
Educate me on the diff's: Scan G vrs Insight CTS
Originally Posted by Idahoser
(Post 11569515)
The Edge Insight is prettier but costs a lot more, and doesn't do everything the ScanGauge does. So what does the SG do that the CTS doesn't??? :-huh |
(Post 11618580)
