brake lights stuck on
I got home today from a quick drive to the hardware store in the '54, and noticed my brake lights were stuck on. Must have been on for awhile, because my lenses are damaged from heat. I am assuming I have a bad brake switch, but just incase is there anything else I should look into? Thanks.
The original type pressure switches are known for failure from corrosion, internal and external. Brake fluid, being hygroscopic, draws moisture that causes corrosion, internal and external. That is one reason why brake fluid should be changed periodically. Of course, make certain the pedal is returning all the way. I went to silicon fluid back when I was playing with this old stuff on a regular basis. I've read that the newer fluids are better.
These pressure switches fail another way in that they take more pressure to activate the light. This is dangerous in that you roll up to a stop while braking easy and the brake lights never come on. Many rear end accidents because of this. |
a bad pressure relief valve in the master can keep the pressure up when you let off the pedal. if you notice any "drag" on the truck when you drive it, that would inidcate pressure when you are not on the break. i had that problem once.
Talk a look at the switch. It maybe out of adjustment. It's most likely the switch is on all the time or the brake pedal arm is to close to the switch. chuck
Originally Posted by 49fordpickumup
(Post 11558045)
Take a look at the switch. It maybe out of adjustment. :-huh It's most likely the switch is on all the time or the brake pedal arm is too close :-huh to the switch.
The master cylinder is firewall mounted. Studebaker cars/trucks used the same switch (#666858 same as C1AZ-13480-A). The master cylinder mounts on the frame rail next to the brake pedal, but this ain't no Studebaker. This switch is notorious for getting gummed up with dirty brake fluid. C1AZ-13480-A (replaced 91A-13480, 0A-13480, 11A-13480) .. Brake (Stop) Lamp Switch (Motorcraft SW-24) / Available from Ford and a gazillion parts stores. Applications: 1939/66 FoMoCo vehicles. |
If you need a new switch, think about getting one from Mid-Fifty. They have one that activates the brake lights with less pedal pressure than stock, allowing your brake lights to come on sooner.
Thanks Bill, I stand corrected. chuck
brake lite on
Hey had similar problem on my 48f1 found out the spring was missing from the brake pedal ftp frame, look up in manual and you will see diagraham,my battery would go dead not anymore hope this helps
It was just the switch. Got it swapped out over the weekend. Now I'm waiting on new lenses.
lite switch
Ok good for you
