Need front frame horns for 52 F-1
Someone cut the front frame horns off on my truck and I would like to buy a couple of extensions to where I can hang a bumper on it. Mine is cut about 6" forward of the rivet on the top of the frame rail to give you an idea of where to cut. I have attached a picture of my cut-off ones. Anyone got some I can buy? tractorman@billstractor.com http://www.billstractor.com/52fronthorn.jpg |
Hi Bill, Keeping my eyes open for ya.
The picture may be deceiving me but looks like the rail is bent in towards the middle? Also I'm curious what others here might know about the F-2 F3 front frame rails maybe being the same as F-1's for possible donors???? Later Josh |
I wish you had posted about a month ago, I just scrapped out a '49 panel.
The front part of a F-2 or 3 might be the same, they have the same front bumper. I don't have my trucks handy to compare. |
when i took the front bumper off my parts truck i cut the horns off when i get home next week ill post a pic and if there long enough you can have them
Thanks for the quick replys.
I'll send another picture but my horns are not bent just short . Tractorman Bill |
https://www.ford-trucks.com/user_gal...id=248302&.jpg are you still looking for this and are these long enough
Mine is cut about 6" forward of the rivet on the top of the frame rail to give you an idea of where to cut. I have attached a picture of my cut-off ones. Refer to the pict. above.
I guess this is about the only reference I can give you since I don't know how much I am missing. Guess I could always extend your horns if they are too short. Bill cell 210-219-6130 San Antonio, Tx. |
Originally Posted by tractormanbill
(Post 11598750)
I guess this is about the only reference I can give you since I don't know how much I am missing. Guess I could always extend your horns if they are too short. Bill cell 210-219-6130 San Antonio, Tx. Hi Bill, Did you find what you needed? I've got an F-1 frame that the back half was damaged and the frame is getting cut up. Let me know if you still need the front frame horns, Or if anyone else may need/want them. Later Josh |
Once the original poster find his set I'd be interested in a set as well. My dad's 52 has suffered the same fate. Someone has cut his horns off to move the bumper in closer.
Thanks Bobby |
Originally Posted by bobbytnm
(Post 12032084)
Thanks Bobby Bobby, I may have a couple from an f3 ? in the near future. i think they may be the same up at the front. ill comfirm that shortly as well and let you know. cheers Josh |
Excellent Josh, thanks
frame horns
Bobby,
I'll neasure and send picts. of the cut off set I got and when I get the measurements off of the full frame I can tell which I need. Possibly we can both be fixed up for horns. TractormanBill |
Sounds good, I'll try and get my dad to do the same
I can't remember how far back his has been cut off. Bobby |
The F-1 frames are a bit different than the F-2/3s. The book says the Maximum Side Member Cross Section of an F-1 is 5.92" x 2.25" x .15". The F-2/3 is 6.0" x 2.25" x .19". Like said, since the front bumpers are the same, these figures probably only matter on the wall thickness measurement, and maybe not even then. Stu
Originally Posted by truckdog62563
(Post 12033371)
Good to know the difference, now I dont need to measure the F-2 frame section. :D Although before I read the above info they sure look the same. here is a picture of the F-2 front end. http://i216.photobucket.com/albums/c...7-10161145.jpg and below is the F-1 rails. 15 and 3/8" from front edge of first rivit to the end of rail. http://i216.photobucket.com/albums/c...7-08171930.jpg http://i216.photobucket.com/albums/c...7-08171902.jpg http://i216.photobucket.com/albums/c...7-08171847.jpg I wont be cutting the f-1 frame until earliest next week sometime so Bill let me know how much you need, heck you can have the entire front half if you want? ;) :-X04 I'll have both the F2 and the F-1 Rails available the F-2 rails are going to get cut tonight or sometime tommorrow how much rail do you guys need? do you need it to go past the front crossmember? Bobby, think these F-2 rails will work? let me know how much to cut? Josh |
