79 ford f100 6bt swap
okey i have been thinkin about this project for awhile and have been all ovr lookin at pics and how to do it. But would rather make a post and get all the information at once. what do i all have to do to make the 6bt fit in this truck i understand the suspension and drive train need to be upgraded. but where can i get motor mounts that will mount right up to this frame without making them and what tranny should i run prefer auto that can take a beating that aint 1000 to buy at a salvage yard but a 5 speed is okey. and how much other parts for the drive train will i need
This thread might help you some...
Welcome to FTE, thornton32. I'll give a link to a similar build. I hope this helps you.
https://www.ford-trucks.com/forums/1...ins-build.html I've been keeping track of that build for the past few days. Enjoy, KBJ |
thanx for the link
Originally Posted by thornton32
(Post 11544104)
thanx for the link
will do still looking for a cummins and tranny so i can start
(Post 11544402)
Count me in for the buildup. There's a pair of good writeups by two different guys on FSB - and I think both double posted the threads here on FTE. Look up the build threads by gos and AmericanThunder over on FSB and here.
Both did very clean, thorough writeups on how they pulled it off. gos' is on a newer chassis, though. AmericanThunder did his on a dentside, so that might be more appropriate for your experience. |
Desided to go with the 7.3 idi got a good deal on a 93 with 105000 on it but my 79 is having problems it has a 360 in it with a c6 auto tranny but I thought the solinoid was junk so i replaced it then it ran now i was goin to put aftermarket radio in to find out my radio harness is cut up an dnt kno wat wires r wat but the main problem is when I go to start it nothing not even a noise from starter or solinoid an nothing works dash lights or running light or wipers fuses r all good Idk wat to do an if u can help can you upload a pic of the radio wires an Wats a as battery wire thanx
(Post 11544402)
Cummins was to much to do swap an I already have a 06 cummins so i was turning to throwing a ford in a ford
(Post 11994530)
Im interested in how this swap goes and how much it will cost you. Im thinking of doing the same thing in an old high boy. Those IDI's are great.
I bought a whole tuning truck so not much which is nice
(Post 11994530)
I ment to say running its goin to only cost me a new tank an having the drive shafts sized
