72 highboy
i am looking at buying a ford f350 that has a restored frame that is a 1975 and the body is a 72. the truck has a slightly built 428 dana 60 axles and a divorse transfer case with c6. new bfgs on aftermarket wheels. the paint and body are all origional, with no rust and some minor dings. does anyone know what this truck is worth ballpark?
The frame will probably be an f250 4x4 if its a 75 4wd frame first year f350 4x4 was 79 anything prior would be a custom conversion does it have power assist steering? Where are you located will depend on what its worth. Around here a truck like you described with minor rust and dings would be around 3000
Originally Posted by minisanf150
(Post 11525873)
Thanks for the info
