Where does this go?
Does anyone have a diagram so I can replace this part? Its not in my Chilton's manual and I am a picture person... I know its a suspension part and is mounted between the sway bar and the lower A arm...
I have a 2001 Ford F150 2wd. http://contentinfo.autozone.com/znet...244HD/image/2/ Thanks! Shari |
Are they gone from both sides? If not then just look at the other side. Otherwise look for the mounting holes between the sway bar (at the end of it) and the lower control arm. It's right out there to see. I do see a diagram in ALLDATADIY but I have a 4X4 subscription and don't know how to post it here.
sway bar end links. They keep the truck from rolling side to side too much whne you turn corners.. All vehicles have them-- watch this.
How to change sway bar end links - YouTube |
I replaced mine on my 02 but everything was rusted together. I wound up having to use a cut off wheel to get them out.
Originally Posted by steve(ill)
(Post 11524717)
Originally Posted by Shari Wall
(Post 11527660)
Thanks Steve - This is perfect... :)
