how to tighten shift linkage?
well, i had a bad habit, resting my hand on the shifter... it is soooo sloppy now,and it wont even go into 1st now.. we manually put it into 1st, so the trans is not the problem... do i have to put a new cable in? or something in the column to tighten.....??? searched, couldnt find anything.
in other news, finally replaced my steady bearing.. a lot LESS road noise now.! used a press to get it off. to do: -shift linkage -trans fluid flush& filter - front diff fluid change -new front calipers -new flex plate -front steering stablizer |
1 Attachment(s)
There are a few things you can check before replacing first would be the torx screws, they are pretty common to loosen up.
Attachment 49564 You can also adjust the linkage PRND2L Linkage Adjustment And to adjust the pointer there is a thumbwheel to adjust Pointer Adjustment Then the actual shifter tube would need replacing if these could not correct your issue. |
you are AWESOME!!! thank you sir!:-X22
Learned about all of it on this forum, so this forum is AWESOME. Just passing along the information. I bet your issue is the torx screws though, mine use to loosen up about once a month until I medium strength loctited them in place.
are those torx screws inside the cab? underneath the panel under the steering wheel? really hard to tell
Yes if you are laying in the floor top of your head against the pedals looking basically straight up they are there, tough to find, but once you know they are there, you can find them every time.
just found the screws. HOT DAMN YOURE GOOD!!! fixed the problem!!! thank you sir!
Glad to hear it was simple.
Sometimes I have to slightly move the shift lever to start the truck. Would tightening these screws possibly fix that too?
Simplest possibility there is.
I will try it tomorrow. Where would we all be without FTE?
BigAl, You must be up late tonight.
I work nights. Then volunteer on call til around 6am
I never have to work in the dark.
All VFR or just the perks.
