Brake Lines
Any recommendations where I can purchase a set of pre-bent brake lines for a 1992 F350? Thanks
no such thing anymore. just go to an autoparts store and get some poly-armour lines they are hand bendable and very easy to use.
lmc truck or national parts depot.
Thanks for the information
Called around to all the big name suppliers, for some reason prebend brake lines for a 1992 F350 crew cab is not available but 1993 and up is and 1989 and below is :-huh
i would have never thought they even made brake line cut and bent to fit directly.
i have never looked into that.it's not hard to grab some line,a decent double flaring tool and make your own lines up.the stuff cuts and bends as easy as pie.pretty cheap and available everywhere. pre-bent brake line made to fit a '93 will fit your '92 of course.if for some odd reason,you find a different connector that doesn't work,you just grab the correct adapter(s.) but i would imagine your going to pay for the convenience and likely still need to tweak lines to fit. |
