In need of body clips to put front end back together!
Hey folks,
just about ready to start putting the front end back together on the 71 F250 Camper Special. Problem is all the body/fender mount clips (whatever they are called) the u shape deals that have a nut welded on one side and it holds the sheet metal together. Where can I get those? Thanks!! |
Hi Chris -
Check Dennis Carpenter's...they should have them: http://www.parts123.com/parts123/yb.dll?parta~partsort |
Hi Steve How goes it!!
Ok so either its too early or just dumb LOL!! The link doesnt load but when I go look on the site I can't find the clips? Which section are they in? Motor and Trans is mounted, gonna drop the cab back on next weekend and start putting the front end back together!! Woohoo!! finally getting Joelle's truck finished! Thanks!! |
Doing well :-X22
See if this link works for you: Vintage Ford truck parts for the F100,F150,F350 and Bronco by Dennis Carpenter Ford Restorations Then go to 67-79 Truck, select "shop online", then select "hardware". I don't know if what you're looking for is in there or not, but it's worth a try :) |
Darn it. Link worked got 40 items in the hardware section but no clips. I'll give em a call! :)
Thanks! |
Found these guys this morning! Great site, a little pricey but you can get ALL your hardware :)
https://www.amkproducts.com/default.htm |
