96 F-250 Powerstroke leaking fuel
i own a 96 f-250 powerstroke which is leaking fuel i am only 15 and dont know a whole lot about diesel trucks...the fuel is leaking at the top of the engine and running down the back where it drips onto the ground...i was directed here by my shop teacher who said you guys know it all so i was hoping someone had an idea of where it was leaking
Welcome to FTE!
It could be a few things fuel bowl cracked, bad fuel lines, bad fuel pump, leaking sensor. The best thing to do is clean it real good start the truck and see if you can see where it's leaking |
alright sounds great thanks a lot for the advise!
Its probably those little rubber fuel hoses behind and down from the fuel bowl. Clean it all up then start it and use a small mirror to look around.
welcome to FTE.
once you find the leak, if you can take a few pictures showing where the leak is to show us it will be easier than trying to describe where the leak is. also tell your shop teacher thanks for the recommendation! :-X22 |
No doubt your shop teacher is a smart guy!
Welcome to FTE! clean it up the best you can and follow theds from the posts up there ^ Stick around and really get to know your truck! |
Originally Posted by Copedawg
(Post 11441055)
Welcome to FTE! X3 about your shop teacher and one more for the WELCOME aboard :-X22 Maybe you are one of the youngest in the forum IDK. :-drink BTW, Ian why you didnt give him your links you have about the PSD? |
I was in a hurry but he was not forgotten
here are some good links you oughtta save: http://www.thedieselstop.com/faq/949...an/stjmain.htm http://www.thedieselstop.com/faq/949...ia/siamain.htm https://www.fleet.ford.com/maintenan...ls/default.asp http://www.forddieselpower.com/forum...ad.php?p=21326 http://www.riffraffdiesel.com/mm5/merchant.mvc? for what this is worth (login is any one letter and anytwelve numbers ie, A123456789012 ) https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL http://www.springerpop.net/F350/Mods.aspx.htm http://www.askamechanic.info/askamec...r+your+vote%21 Again WELCOME! |
(Post 11441558)
here are some good links you oughtta save: 1996 Bronco/F-Series Workshop Manual 97-15A 7.3L DI Turbo Workshop Manual https://www.fleet.ford.com/maintenan...ls/default.asp Exhaust removal gone horrible. - Ford Diesel Power Forums Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts for what this is worth (login is any one letter and anytwelve numbers ie, A123456789012 ) https://elibrary.mel.org/validate?ur...ch%3Fdb%3DCHLL Powerstroke Mods and Maintenance Ask a Mechanic - A deep look at the 7.3L Power Stroke Again WELCOME! :-drink |
Originally Posted by oldbird1965
(Post 11440231)
