Engine Mounting Kit for 351M
I am wanting to installing a 351M into a1960 F-100. Is there a engine mounting kit made for this. If so, where can I purches one.
fomocodan |
The 351M or 400 engine is not that common in swap type applications. They are also unique to themselves. I have not seen anything specifically for those. You see a bit of the small block 289 302 351W 351C mounts, then the FE 390 etc type, and 429 460 engines.
Jegs has the weld in type. I haven't seen any bolt in ones if that is what you need.
Trans Dapt 4513 Trans Dapt Universal Street Rod Style Bushing-Type Motor Mounts |
