Comparison to PWR Wagon 5.7 Hemi
Anyone know of a comparison between the F250 6.2 and the Power Wagon Hemi?? Have to say, the Pwr. Wag is an awesome truck. At least awesome looking.
http://www.tunner.org/wp-content/upl...Angle-View.jpg |
Wonder what the mpg is... rear end is a 4.56!! That's a purpose built vehicle.
I like the 1500 rams but as far as 2500s go, Rams would be last on my list gassers anyways. Appearance wise, they don't look anywhere near as stout as Fords or GM for that matter. I love the height of the Fords. Dodge just doesn't seem to compare. JMO. 1500, I would consider dodge, ford, gm and toyota. I really like the snub nose look of the toyotas and the outside door handles on the scab models. I don't much care for my ford interior door handles. It get's old after a while opening two doors all the time.
scab vs screw
as far as the Toyotas go, I like the looks of both the scab and the screw. But, the screw's cab is just too big. The rear seat reclines and slides forward. Its huge.
the Toyotas scab is just about right and the exterior door handles and normal opening rear doors are nice. Ford's scabs seem cramped. Dodges and Chevy's scabs are better. |
Originally Posted by Brandon150
(Post 11429367)
(Post 11429367)
Ford 6R140 1st 3.97:1 2nd 2.32:1 3rd 1.52:1 4th 1.15:1 5th 0.86:1 6th 0.67:1 Ram 66RFE 1st 3.231:1 2nd 1.837:1 3rd 1.410:1 4th 1.000:1 5th 0.816:1 6th 0.625:1 As an example, lets look at the first gear of each: Ford: 3.97 first gear x 3.73 gearset = 14.8:1 final Ram 3.231 first gear x 4.56 gearset = 14.73:1 final So even with 4.56's for the Ram and 3.73's for the Ford, they're almost equal in first gear. They even both use the same transfer case (NV271) with the same gearing, so the Ram doesn't have any advantage in 4Lo either. Both end up being about 40:1. So, basically, a Superduty with the optional 4.30's is geared way lower than a Power Wagon with 4.56's. A good thing to know if you're looking for the best ratio for off-roading.:-X04 |
Originally Posted by ommegang
(Post 11429394)
Loaded? Fordsare just a lot taller than copmetition. Makes me feel safe and you get used to being up tall. And, it's hard for other 's to see what's in the bed, like tools. They don't sag 1 inch with a 9'2 plow in front. But, the ass does sag when loaded. I wish mine had helper springs.
Originally Posted by 1badfish
(Post 11429234)
http://www.tunner.org/wp-content/upl...Angle-View.jpg Comparison? Hmmm...I suppose what you are comparing. Whether it is towing / hauling or offroad climbing rocks. The SD will dominate in the towing and hauling. However...we have NO chance when it comes to offroad. The e-locker in the SD helps...but we loose so much with articulation and front / rear lockers. <iframe width="420" height="315" src="http://www.youtube.com/embed/cpeo7STWSF0" frameborder="0" allowfullscreen></iframe> The Power Wagon is an awesome truck...for what it was built for...agreed. biz :-X22 |
biz is right on the money. I've been looking hard at buying a Power Wagon for some time now, but have decided to stick with my beater for now. Generally speaking, the Ford has more options, is cheaper, and will tow and haul more weight safely than the Dodge will. The Power Wagon is built for off-road capability and will shine there.
I still can't convince myself to buy a Dodge, even if the Power Wagon is cool. :) |
