Fuel leak
well it seems all the high milage wear parts decided to go out all at once.
i have a fuel leak behind passenger head from the fuel supply line. there is a rubber hose that connects to a metal line. seems a simple fix,anyone know where i could buy a kit,or new hose to attatch to the line? or do i have to buy a new section of line? I'll have all thses pesky easy fixes fixed soon (i hope) thanks in advance:-wink |
Originally Posted by IBleedOvalBlue
(Post 11427007)
i have a fuel leak behind passenger head from the fuel supply line. there is a rubber hose that connects to a metal line. seems a simple fix,anyone know where i could buy a kit,or new hose to attatch to the line? or do i have to buy a new section of line? I'll have all thses pesky easy fixes fixed soon (i hope) thanks in advance:-wink well how many miles you have? wonder if it has anything to do with the texas heat? when i was in arizona, rubber didnt stand a long term chance. |
(Post 11427007)
i have a fuel leak behind passenger head from the fuel supply line. there is a rubber hose that connects to a metal line.seems a simple fix,anyone know where i could buy a kit,or new hose to attatch to the line? or do i have to buy a new section of line? I'll have all thses pesky easy fixes fixed soon (i hope) thanks in advance:-wink There is a wear spot at a p-clamp that secures the fuel line about half way back that some put a piece of split hose over as a preventative measure. I did. Pic taken with fuel bowl removed while I was doing an HPOP R&R. Right in the center you can see where I added the the split hose and put the p-clamp back on. https://www.ford-trucks.com/forums/a...5&d=1309561786 |
270k,and its all orginal,only work ever done was service by ford.
i think its just the miles and age,just have to find where to buy a new line or replacement rubber line. |
it's behind the passenger head,where the lines dip down at the firewall and down behind the block,it looks like the metal line is incerted into a rubber line there,i could be wrong.
(Post 11427124)
There are no fuel lines that go down behind the block. I don't understand what you are describing. A pic would be nice. |
well it seems to on mine,its an 02 7.3
and how do you post a pic,all i get is a http link,not a browse:-huh |
(Post 11427233)
and how do you post a pic,all i get is a http link,not a browse:-huh Then you can browse your computer for the pic and upload it. |
well i must not have that privilage
only thing under additional options are Miscellaneous Options Automatically parse links in text Automatically retrieve titles from external links Disable smilies in text Thread SubscriptionNotification Type: Do not subscribe No email notification Instant email notification Daily email notification Weekly email notification Rate Thread If you like, you can add a score for this thread. Choose a rating 5 : Excellent 4 : Good 3 : Average 2 : Bad 1 : just seen this You may post new threads You may post replies You may not post attachments http://i1170.photobucket.com/albums/...k/fuelline.jpg this is what caused my starter fuse to blow,diesel is leaking down on it.i smelled it and it is diesel. |
(Post 11427007)
i have a fuel leak behind passenger head from the fuel supply line. there is a rubber hose that connects to a metal line. seems a simple fix,anyone know where i could buy a kit,or new hose to attatch to the line? or do i have to buy a new section of line? I'll have all thses pesky easy fixes fixed soon (i hope) thanks in advance:-wink Replacement O-rings for Ford Diesel Engines http://www.dieselorings.com/prodgfx/15.jpg this is the fuel rail connection sleeves that you may need. |
