glow plug relay...............again.
yea, i know i ask this question every year, but i am old and senile.:D
which one is the GPR, front or rear? |
1 Attachment(s)
Originally Posted by tjc transport
(Post 11421422)
TJC: I bought one from someone on this forum a couple of years ago, and it has worked just fine for me. It wasn't the big one, but he was claiming a heavier duty than Ford had.
yea, i am looking for another stancor. the one i got last year must have been defective cause it did not last 11 months.
but i need to put a napa unit in it till i can find another stancor. |
(Post 11422095)
but i need to put a napa unit in it till i can find another stancor. You should just use the AIH relay for the GPR until you can get a Stancor. |
I use Boss plow relay it HUGE one. Been on for 1 month. No problem. 10 sec of glow plug ON it start in -5oF.
http://i21.geccdn.net/site/images/n-...UE_1304719.jpg |
Originally Posted by PaysonPSD
(Post 11422427)
You replaced the stock GPR with a Stancor and then you ask which is the GPR. What's up with that. :-huh Are you sure you should be doing this yourself? :)
You should just use the AIH relay for the GPR until you can get a Stancor. and the AIH relay is bad. i know that because when it went the first time i swapped them and never replaced it. |
(Post 11423429)
the stancor i used is the 100 amp unit that looks just like the stock GPR.
and the AIH relay is bad. i know that because when it went the first time i swapped them and never replaced it. Like Rosanne Rosannadana (a Gilda Radner character on SNL) used to say "If it's not one thing, it's another". :-X04 And when it comes to Powerstrokes that is so true. |
ain't that the truth!! eventually i will get a 200 amp relay, then i will never have to worry about it again.
Originally Posted by megawatt00
(Post 11423661)
$52 for Stancor or Boss plow relay that only $17 |
(Post 11423661)
yup, that be the one Jim. i just have to wait for it to get here but i still have to put a GPR-109 in so the truck will start until it gets here |
Originally Posted by Milwaukee1979F150
(Post 11423840)
(Post 11425657)
that boss plow relay is only rated at 50 amps, just like a starter relay or the GPR-109 from napa.
Where you see 50 amp label? They are HUGE than starter relay. It weigh heavier. Reason I pick this boss relay because I have see some fleet with those relay that still work for 10 years of commercial plow. Those would be running for about 15-30 hours every snowstorm so it see alot works than normal starter relay see. Trombetta 12 Volts 4 Terminal Intermittent Duty Starter Relay Insulated Case Plastic Housing 5/16"-24 Copper Contacts. Narrow Curved L Bracket 150A Carry, 800A Inrush,25% Duty Cycle References: Replaces Trombetta 684-1251-212 Can Replace 3 Terminal Relay 634-1261-212 Just Add Ground Wire |
Do u have a, boss part number ?
