Block Heater Power Consumption
I was just curious how much power the block heater uses.
so did i, i put an ampmeter on mine and got just under 7 amps. about 840 watts
I think theyre 1000 watts.
This was discussed a while back, someone said the oem was 1500 watts and aftermarket was 1000, but the 1500 wasnt confirmed. If you're wondering how much it costs to keep it plug in it works out to around 10 cents per hour in most parts of the country.
960 Amps ....
960 amps?!?! Must be a mis-type? I think rail cars in new York use less than that.
Originally Posted by chicagodragon
(Post 11415693)
:-partybud:-partybud |
Yeah, around 1000 Watts is what I have always heard.
Block heater
have a timer on mine. I usually set it for3 hours before iI need to leave. It keeps the costs down but has enough time to warm the block.
Doc |
its about $0.08 an hour for me. I leave it plugged in most of the time if its less than 32° outside. I have a pretty random schedule and I just like to be ready go at all times.
Very interesting.. I have always wondered... Especially with CowMilker there! .08 an hour.. Hmmm...
I have stock tank heaters that use the same juice! LOL |
Tank heaters?
(Post 11434820)
Tank heaters?
Originally Posted by Midwest Dually
(Post 11434727)
I have stock tank heaters that use the same juice! LOL I just use a power timer thing rated for 10 amps. When I plug er in at night I set it to come on 4 or 5 hours before I gotta get out to start it before work. If its REALLY cold I leave her on most the night. |
"Stock tank heaters" -- heaters for stock tanks (i.e. watering animals), not (fuel) tank heaters that are stock. One of those things where even punctuation won't help you.
$0.08 / hr is a very good rate. We pay $0.15 / kWh (which, given the BH draws exactly 1000W equals $0.15 / hr), so a timer pays for itself pretty quick. |
