Something broke under the bed... Don't know what it is...
I noticed when towing or with a heavy load in my bed i get a lot of squeaking or strange noise. I towed my 23k lb trailer yesterday, dropped it off, then put some heavy stuff in the bed. When i was unloading standing in the bed, it was making a creaking sound. I started jumping up and down looking like an idiot to find out where it is coming from. It seems to be coming from the drive side rear. I unloaded the bed, jumped some more, and it was not really doing it, unless i jumped around hard on the very end of the bed on the driver side. I got out took a flashlight (night time) and looked under the driver side rear, right infront of the bumper i spotted a large metal circle, with 2 rubber ends on it. And the rubber end on one side is totally cracked off, and the other side, almost cracked off. I assume this is what is causing this sound, my thing is, what is this damn thing? I looked on the passenger side and there is nothing there. So whatever this is, why is it only on the driver side rear?
here is a pic.... (please ignore my sloppy wiring job, those wires go to a reverse camera i recently hooked up). http://desmond.imageshack.us/Himg19/...jpg&res=medium |
I have no idea! I will have to see if I have that..or I wonder if this is F450 item only.
On edit. I think they may have to do with the rear springs. |
suspension pics
1 Attachment(s)
see if you can identify it here
Originally Posted by senix
(Post 11414510)
I looked at this some more again. It is not connected to the suspension. It appears it is some sort of bump stop for the bed? not sure, but it looks like something like that. I am probably totally wrong. I looked in my service manual under suspension and under pick up bed, and found nothing!!! Still need help!
That's a vibration damper. Part #5D008. Only in 450 and 550's.
Darn it! RM beat me to the answer.
2X on the damper. |
Originally Posted by RM2738
(Post 11419795)
It helps to adsorb vibrations in the tail end of the frame.
http://en.wikipedia.org/wiki/Tuned_mass_damper Spray it with some silicone lube to see if the noise abates. |
Originally Posted by shorebird
(Post 11420107)
Tuned mass damper - Wikipedia, the free encyclopedia Spray it with some silicone lube to see if the noise abates. |
(Post 11420276)
The rubber in the unit has been severely damaged from what the OP has stated. It most likely could just be removed so it doesn't cause the noise. Replacement seems to be somewhere in the $400 range unless you can find an aftermarket.
I wonder if this is replaced under my extended ford warranty? Yes, mine the rubber is totally cracked and spray i cannot see helping. I still somehow do not understand how this thing works, it almost appears to be connected to nothing? i am tempted now to see if i take it out if it still makes the sound? also curious why only the F450 and 550 have it... |
Originally Posted by ETKMS
(Post 11420475)
$400!!!!!!!!!!!!!!?????????:-hair:-hair:-hair WOW!
I wonder if this is replaced under my extended ford warranty? Yes, mine the rubber is totally cracked and spray i cannot see helping. I still somehow do not understand how this thing works, it almost appears to be connected to nothing? i am tempted now to see if i take it out if it still makes the sound? also curious why only the F450 and 550 have it... I would assume that it's covered under Ford X warranty. |
