F450 Rear Disc Brake Bleed Issue
I've got a 2002 F450 V10 4x4 with rear disk brakes. I bought this truck a year ago with the intention of really using it at a later date. I recently noticed that both rear calipers were not functioning and that one of the rotors actually had one side completely ground off and this had likely been in this state since the previous owner as the pads were still essentially new.
There was no problem stopping the truck, even under load but as I want to start using the truck on a regular basis I decided to replace the rotors, pads and calipers. However, after bleeding the brakes for hours, cycling through at least 8 litres of fluid and including using a pneumatic power bleeder, I am unable to get the stiffness of the brakes to the point they were before I started. Brakes will stiffen up just fine until truck is started then they are spongy and will eventually travel to the floor. Truck will stop while on a road test but definitely not tight like it should be or was before. Anyone had experience with this sort of problem? Hate to just start randomly replacing things like a dealer. |
Are you still getting air out of the bleeders?
Perhaps there is air in the ABS module. If there is air in the ABS module, you have to take it someplace that can hook it up to a computer and cycle the solenoids to bleed the module.
Are the bleeders on the top of your calipers?
Originally Posted by critterf1
(Post 11390797)
Originally Posted by bucci
(Post 11390797)
Originally Posted by T diesel
(Post 11390797)
Both bleeders should be on top.
(Post 11393458)
I`ll exchange tomorrow and update. |
Happened to me!:o
I believe you have to specify front or rear mounted. |
Did you get the problem solved?
(Post 11393458)
I removed the caliper, turned it upside down with a shim between pads and bleed it this way. |
Mine are on top.
nightmare brakes
I had the same problem with my 1999 F450,it is easy to get the wrong calipers,bleeders have to be on top to bleed properly,invest in a $50 vacuum pump as these calipers are huge and pumping the brakes too soon just adds more problems,was able to remove most of the air with the pump and a couple of brake pedal pumps with a helper got rid of the rest.Had a bit of an issue with low pedal when first starting truck but a few hard stops and the pedal was better than before.When bleeding calipers,it is easy to know if the air is out as they will start working as your helper is applying pressure while you are working the bleeder.
07 f450...
I've got an 07 f450 here... Replaced rear pads, rotors,and calipers, bled system... Even hooked a computer to it to bleed abs actuators... Still have no rear brakes, front will lock up...
Who ever told you that Ford only makes 1 rear caliper for these trucks, so that one will have the bleeder on the bottom is smokin' something and it ain't good ****. Both bleeders are always on top, there are 2 different part numbers depending if both calipers are mounted behind the axle or if 1 is mounted on the front side of the axle. With the bleeder on the bottom it is all but impossible to get all the air out of the lines, without a lot of extra work. Also air in the ABS does not always set a code. If the brake pedal slowly goes to the floor you may also have a bad master cylinder.
