Audiophile Not Working
I have a 2005 Expedition Eddie Bauer in dash audiophile 6 cd/ fm/am radio. About a month ago my cd player started reading disc error, I removed and checked the fuses, after I put them back in the cd player read no cd and the radio worked fine at the time.
Today I had to replace the original battery and now my radio has no sound, it will come and the clock I can see the volume bars when I turn up the volume, but no sound. I did notice that the radio clock and light went dark and came back on twice. any suggestions? Thanks |
If an aftermarket unit will fit in the dash, you might consider getting a unit with SD card capability and dump the disks. No moving parts, far more storage capacity, no lasers, and you can step up the capabilities of the unit to include a backup cam. It's just a thought.
It sounds like your unit may be done, but you might have a loose ground or the connector in back of the unit needs to be unplugged and re-inserted (if you're lucky). |
This thread may help you out (if it's the same head unit):
https://www.ford-trucks.com/forums/1...air-fixed.html |
Update
Originally Posted by Vezhen
(Post 11319967)
