Originally Posted by truckdog62563
(Post 11311783)
You two need to compare notes. Might be the same truck.
Owen - have you had a chance to run down the third F-3 M-H that you've mentioned that's up around Williston? IIRC you said it's the one with a fx'd front axle, but even so it'd be a great donor. Stu I haven't had a chance to look for the third M-H. On my short list to do. I wonder if we are talking about the same F1? |
Originally Posted by CHUCK48-50
(Post 11315171)
I thought I would answer a couple questions at once.
M-H always did their own steering ends in house. They bought pumpkins without tubes from Spicer, and installed their own, with their own ends. NAPCO first offered kits for Fords in 1956. The earliest ones used a Chevrolet front axle, with 6 lug wheels. And no, they didn't bother with any kind of adapter to change the pattern for the rear. Some time in 1956 they switched to the Spicer 44. I'm sure these were completely built by Spicer. And they all used the model 23 transfer case. Chuck |
Originally Posted by thundersnow70
(Post 11315224)
thanks for clearing up the MH front axle question Chuck. So harleyg, do you have six lug on the front and five lug on the back? Chuck, gonna send you a pm.
(Post 11310895)
Chuck might want to comment, ...
(Post 11315171)
M-H always did their own steering ends in house. They bought pumpkins without tubes from Spicer, and installed their own, with their own ends. Chuck
(Post 11315224)
Went to the other shop today: FIVE lug, front & back !! |
You have the later, Spicer 44 axle. It was built for a Ford, so it has 5 lug wheels. If your truck was an earlier 1956, it would have had a 6 lug Chevrolet axle.
Stu, Yes, your axles are Timken. 1/2 Tons were Spicer. This post is about an F-100, so that's what I was referring to. Chuck |
Chuck - I didn't say it well. I was asking if M-H also added the tubes and steering ends to the Timken cases used on the bigger models? Stu
(Post 11318903)
Stu, Yes, your axles are Timken. 1/2 Tons were Spicer. This post is about an F-100, so that's what I was referring to. Chuck Thanks: appreciate the info and your knowledge !! |
(Post 11318968)
Yes, the bigger axles were assembled in house as well. Chuck |
Thanks Chuck. Stood to reason based on your first statement about the Spicers, but just wanted to be sure. Would have liked to have seen the machinery they used to (I assume cold) set the rivets in the joints where the axle tubes connect to the case halves. You told me once that you'd replaced a broken axle tube once, am I remembering right? Did you have to make a jig to reach inside for setting the rivets? Stu
I just stuck a piece of round stock in (after putting rivets in all of the holes from the inside). I have rivet setting tools for my air hammer.
Chuck |
Oh, that's straight forward. Thanks. Stu
