51/52 Dome light wire diagram
Hi ,I recently purchased a stock Dome light to go in my 52 F1, Does anyone know where I can get a wireing Diagram for the Dome light? There is a wire coming straight off the single pin 1129 bulb , but there is a toggle switch on the steel flat bar mounting bar. It appears this is for turning on and off the Dome light when the doors are closed. ?? Thanks, John
Welcome.
The Shop Manual has wiring diagrams for the full F-series line. You might also check at: http://www.clubfte.com/users/earl/Re..._Material.html Happy Motoring! DW |
You can get an excellent, 11x17 laminated wiring diagram for your truck (minus turn signals) from ClassicCarWiring.com
Full Color Laminated Wiring Diagrams for Classic FORD Trucks |
