bed swap
will the bed from a 1984 F250 fit on a 1991 F250 if so will the body lines match up? I know the tailights and tailgate are different but I can live with that
Not real sure about the mounts on the btm, I imagine that you would have to make adjustments at the frame. It appears that the top rail lengths are the same.
Maybe someone else has some more info. |
The wheel arches are diff. The 80-86 are more squared it'll fit, just look different.
yeah all the mounts are the same IIRC.
Bed swap
Thanks for all your help, wow are the wheel well opening different, thought I had look at all of it but man was I wrong:)
You could swap the front clip over too. Then you'd have the sweet flat nose instead of the 87-91. I think it'd be sweet
