Rear end rebuild
So I am pretty sure my rear end is having issues the rear tires locked up (one one way the other going the other way) on christmas eve at the inlaws. So tomorrow I am going to tear into it and see what the hell I broke. It is a 2001 F350 cc srw i believe it to be 3.73 gear dana 60 spliner... I could be wrong would not be the first time. What I am looking for is ideas from you guys on where to get good aftermarket parts for the repair. I would like to upgrade alittle but only if it is close to the same $$ as putting ome back in it. I may end up just buying one from a salvage yard depending on what damage was done. i was able to drive it home after it broke with a little bit of grinding in the rear end. Any ideas would be great but please tell me not just what to get but where I might go about getting to also. Thanks a million.
Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts
Clay can get you all the parts you want at the best prices. Theres not much better than OEM when it comes to R&P, but if you're thinking of regearing now's the time to do it. Your rear-end is a Sterling 10.5", the Dana 50/60 is up front (most likely a Dana 50 with it being a 2001). Good luck. |
Turns out just a spider gear broke it half. A local guy had all the parts for 60 bucks the oil was 80 though lol fixed and back on the road. Priced a detroit locker while I was there said 550 for the kit. maybe next time...
