code tag sticker fell off trans. important?
I was under the truck and noticed this sticker nearly fell off. Is this important? What is process gear? Is this factory or has trans work been done?
http://i283.photobucket.com/albums/k...6/IMAG0193.jpg |
Thats off the transfer case. You can glue it back on with a dab of silicone.
I'd glue it to the inside of the glove box, in case it decides to flake again.
New Process Gear is the company that built the transfer case. That sticker is to identify the transfer case in the factory.
Thanks guys
Scott, guess you can hand that piece of paper over to a Prius owner to recycle for you!
It might make you feel good...}> |
