Ford Y Block Oiling Fix
i looked at the passage in cylinder head
that carries the oil over about an inch from the gun drilled passage in block to the the passage in the head up to rocker shafts having the engine apart to rebuild it the passages will be clean and clear this is from Wikipedia 'Ford Y Block' 'The motor oils of the era were low in detergents, but high in coke; when combined with short trips and infrequent oil changes, this led to blockage of this passage' i'm just going to put it back together and leave it alone new better oil and oil changes will make it trouble free |
:-blah :-blah :-huh
i'm just going to put it back together and leave it alone new better oil and oil changes will make it trouble free That's a GOOD plan. It probably wouldn't have been required even in the "old days" if people had just changed the oil and filter more frequently. Todays oils can be run MUCH longer (because of better detergents) before sludge becomes a factor. With a new tight engine, ANY good 15W-40 oil will be satisfactory. Once my 292 is broke in, I'll probably run Shell Rotella or Mobil-1 Turbodiesel Truck 5W-40 synthetic. Cheers, Rick |
I remember the issue's well. The good old Quaker State parrafin based oil sure did a number on clogging them up.
Make sure the groove in the cam is sufficient, about 1/16" wide and 1/32" deep. This will prevent the bearing material from blocking the supply.
