2001 4.0 SOHC intake picture
Can anyone post a picture of the, top of the engine with the plastic intake manifold removed or the bottom of the one piece plastic intake manifold that shows the gasket surfaces for this years engine. This is different than the 97-2000 two piece manifold and I have been unable to find it anywhere.
Another PO174 code with a rough idle solved with new intake gaskets. Can't say as I have ever seen that much gunk and oil in an intake before.
Is this what your talking about?
http://i1134.photobucket.com/albums/...tge/photo3.jpg If you need one let me know I have one off of a brand new motor never ran didn't need it. We could probably work out some sort of deal. |
Thanks for the response. The reason I wanted a picture was that my manual only showed the two piece type but said mine was a one piece. I wanted to make sure that I had the right gasket set before I tore it apart. Once I tore it apart it turned out to be the two piece manifold after all.
