22" Wheels on Expy EL ?
Anyone have 22" Wheels on their Expy EL,
What size tires are you running on them? Whats the biggest ratio you could have with out them rubbing? |
I've seen aftermarket 22's and they godawful
The factory 22" rims are pretty sweet. The 04-12 F-150 uses the same rims. The Harley and Limited get 22" rims from factory. These bolt up very nicely. The width is 275...can't remember what the height is. I do know that a 33" overall diamter will fit a 4x2 or 4x4 Expy perfectly without rubbing...cause I'm running 33" on my 4x2 right now |
04-08 Harley Wheels would work nicely. 275/45/22
I've got a set of 22's on my wires limited el 4wd. No rubbing. No issues. I believe they are 275/60r22. Khumo. If your interested in a good used set get ahold of me. The wife wants the factory 20's back on it for our hilly terrain.
Tire size correction.
The tires we are running are sumo 305/40/22.
For summer im running a set of 22" driv tantrums with 305/40r22 lexani roadian hp tires. Had factory mud flaps on but they rubbed on those. Without the mud flaps theres no rubbing. Winter setup is stock 18" wheels with 255/70r18 bridgestone blizzak winter tires, which is the same size as the original factory tires.
Wifes got 285/45/22. No rubbing.
