where is the fuel filter in 2003 expedition
I have looked all over and can not find the fuel filter in my 2003 expedition with a 5.4.
Originally Posted by chubbybubby
(Post 11080257)
I needed a fuel line hose removal tool, and got a shower of gas, lol. The filter was $10. Ford wanted $75, so told my wife it was my $65 savings shower, so was worth it, lol |
Before removing the fuel lines, release the line pressure at the schrader valve on the fuel injector rail. Fuel won't spray out when the line is removed but have a catch pan available to capture the residual fuel in the line and filter.
NVM, it's the newer ones...
Well found the hidden fuel filter. Was right between the gas tank and frame rail hidden under plastic cover that blended in with the gas tank cover.
Start the engine then pull the fuel pump relay or fuse and wait for the engine to die. This will relieve the fuel pressure from the fuel line. Do not reinsert it until you're done installing the new filter or the pump could turn on.
