torque converter to flex plate advice?
I am mating up my transmission to engine and I am wondering if there is an easy way to align the torque converter bolts to the flex plate? I am trying to get it aligned AND pulled in by myself. C6 to 351.
Thanks |
If you take the spark plugs out you should be able to spin the motor fairly easy with a socket on the front of the crank or find something you can use as a lever to pry against the ring gear on the flexplate. Tony
Just did this yesterday by myself.
Be sure the torque converter is COMPLETELY seated. There is the input shaft, stator support and oil pump drive to engage. I set the torque converter so the four studs are at 12, 3, 6 and 9 o'clock position. Then I turned the engine so the holes in the flex-plate are in the same position. I then set the engine in place and got the bell housing bolts started by a couple of threads. Got under the truck to make sure everything lined up. It didn't, alignment was off by a hair. I used a long screwdriver to turn the flwheel enough to get everything lined up. Then tightened the bellhousing bolts to bring everything together. |
Originally Posted by mikeo0o0o0
(Post 11058378)
Be sure the torque converter is COMPLETELY seated. There is the input shaft, stator support and oil pump drive to engage. I set the torque converter so the four studs are at 12, 3, 6 and 9 o'clock position. Then I turned the engine so the holes in the flex-plate are in the same position. I then set the engine in place and got the bell housing bolts started by a couple of threads. Got under the truck to make sure everything lined up. It didn't, alignment was off by a hair. I used a long screwdriver to turn the flwheel enough to get everything lined up. Then tightened the bellhousing bolts to bring everything thogether. Thanks and I will update later today I hope. |
I think I just need to suck the bell closer If you are having to use bolts to "pull it together' then your torque converter isn't seated correctly and you are about to DAMAGE the pump inside ($$$$) your transmission. Please be careful and make sure the torque converter is seated in the pump. Rotate it till it aligns and you feel it drop in place. |
It always helps to start a few longer bolts in the bell housing to get it lined up.
It seems like the torque converter is in to far still lol How close should the bell be before the torque converter bolts start to touch the flex plate?
Once it's that close it should just wiggle into place.
Been a while since i stuffed one but it's about the same. When the bell housing is against the engine block the torque converter sud shoulder will be thru the plate and should have a small clearance to the flex-plate. I don't know the measurement but at least 1/16th; maybe even a 1/4 in. So when the studs contact the plate the bell housing should be less than the length of the studs. I think that's right? Just don't force it and you'll be ok I'm not explaining this very well... Could someone help. Thanks! |
Originally Posted by OldStyle
(Post 11058754)
Been a while since i stuffed one but it's about the same. When the bell housing is against the engine block the torque converter sud shoulder will be thru the plate and should have a small clearance to the flex-plate. I don't know the measurement but at least 1/16th; maybe even a 1/4 in. So when the studs contact the plate the bell housing should be less than the length of the studs. I think that's right? Just don't force it and you'll be ok I'm not explaining this very well... Could someone help. Thanks! Josh |
(Post 11058754)
(Post 11058754)
Originally Posted by gfw1985
(Post 11058828)
You're doing fine. If you have to force it, somethings wrong. Never pull it in with bolts. Yes, four studs or bolts with heads cut off are nice to keep things aligned. Only possible thing I can think of that they are too far apart, is having the flexplate on backwards or wrong flexplate. Usually torque converter is too far out due to not being seated all the way. Good luck.
Josh |
I am pretty sure I have the flex plate on correctly. I think I just need to pull it a little closer and turn the engine a wee bit more. Just wanting to make sure is all. I will be down in the shop shortly and will see how she goes.
Thanks for the help. |
Thanks for the help, I got it all bolted up. now onto the rest of the job.
