2008 left/rear thump, at a loss.
Hey Guys,
I have a weird “thumping” noise coming from the rear drivers side wheel area. It does it only when I hit a bump and seems to do it more when I am slowing down/breaking. The very odd time it goes from a loud single bump to almost a vibration. I have only heard it do this once, but my wife said it has done it a couple of times. The vibration only seems to do it while braking over a large bump, but again it is rare. It sounds more like it is coming from the inside than the outside. I took the wheel off and checked suspension. I thought it might have been a loose shock mount, but everything is tight. I had my wife drive while I sat in the back, and it is almost like it is coming from the inside, but I have no idea what it could be. I might have thought it was the sub with a loose connection (is it in this area?) causing it to “thump”. When I had the tire off it appears the brakes are new (new pad and rotors) It is not the access panel to the jack or the jack itself, as I removed them and it still did it. I also tighten the spare tire as I thought that might have been bouncing. I’m at a loss. Thanks everyone! |
It could be the traction control. Mine does it mostly when turning over a bump at slow speed.
good call, never thought about that.
Now is this a normal sound? lol |
The Thump is pretty loud. you can hear it over the radio.
Mine is loud enough. Whether or not it's normal--I'm not sure, but mine has been great so far. I don't know how loud your radio was at the time, so I can't comment on that.
Just curious do both you guys have the rear air suspension?
Matt |
No, no air suspension
Did you check the spare tire? Might be loose.
Had that happen on a truck once. I felt real stupid after checking everything but that for the issue. |
Originally Posted by function12
(Post 11048076)
Had that happen on a truck once. I felt real stupid after checking everything but that for the issue. I did check the spare tire. Unfortunately it did not solve it. |
Originally Posted by RI-Matt
(Post 11045553)
Matt Hi Matt, No air suspension. |
Originally Posted by kennisonxgs
(Post 11042726)
as I was pooking around tonight trying to find the source, my son slammed the passenger door and I heard the thump in the rear. So I am leaning away from suspension. the more I think about it the more I am thinking sub with a short. Is the sub in the rear drivers side under the window? |
Originally Posted by ibyers
(Post 11054438)
the plastic moulding has a grille looking thing behind the drivers 3rd rear seat. that's the sub. I had my Expy for >1 yr before finding out I had one |
Do you guys think it might be a loose body mount?
(Post 11061098)
