Fan Clutch Removal
When facing the truck, do you turn the fan clutch nut left or right to remove? Thanks in advance!
Steve |
Did you know that when determining Right and Left on ANY vehicle, that it is as if you are sitting in the drivers seat? I do believe that that nut is a standard right hand thread tho.
So tighty is righty. |
Bud, thanks for the reply.
Yes, I do know that right and left is determined from sitting in the vehicle; the fan clutch is a little hard to reach from in there tho! (lol) As I figured most people will be facing the truck when removing it, I asked the question from that point of view. Thanks again! Steve |
Welcome Steve.... I like to throw in little bidbits when I can....others can learn, right? Have a good day!
Probaly TMI }>but I had to remove mine last year. The nut is left to loosen facing the front bumper. Mine was a real PITA.:-arrgh Some folks get it with no problem. I tried everything from buying a removal tool from NAPA and using the strongest air hammer Snap On had... to beating it with a 8 lb hammer. Would not budge. I am not trying to discourage you just a heads up. I decided not to stress over it and went on to other projects. No. it did not remove itself. For the next 2 days anytime I walked close to the X I hit the bar with a BFH once or twice and moved on. Second day second try it broke loose and you could turn it off with your hand. ......Good luck...
A pipe wrench worked great for me the last time I had to remove it.
https://www.ford-trucks.com/forums/8...pump-info.html |
Thanks for the info men.
Steve |
I have given up on the left/right thing. I see people mix it up sometimes. I use driver/passenger side. No confusion. :)
What they said...righty tighty, lefty loosey and I used a pipe wrench with a breaker bar as well. The real trick was holding the pulley from turning. I finally was able to do so with a long 1/2" drive extension with 3/8" adapter on the end and in the hole but only after wasting two large, perfectly good screwdrivers.
