Rear Diff Fluid Topping Off
Team, I have a question? I have what I thought was a minor rear diff seal leak! So, I start to top off, and used 1 qt of fluid. Is this bad news? I am scheduled to have this seal repaired next Thursday. The rear diff did not appear to be that wet. Any opinions are welcomed.
It could have been there for a long time and you didnt notice it. Just top it off. Youll be fine but I would check it every few days so you know just how bad it is and if its low again just fill it up until you can get it changed
you did fill it at the plug on the driver side of the diff ?
a quart is about 1/3 of the total capacity of diff, I would be real surprised that the diff wasn't wet |
Check the vent tube and make sure it is not blocked or pinched.
Chet |
I've been there and done that with a pinion seal leak. Just keep it full from now on and don't worry about it. It got a little low and there's nothing you can do about it now. I would bet good money you won't have any further problems. I didn't.
Originally Posted by Bonanza35
(Post 11027274)
Chet |
Originally Posted by microdevil45
(Post 11027373)
This is to keep it from pressurizing correct?
So...Team, you think that some over heating damage may have occured In the rear diff?
I went on a 300 mile trip pulling a heavy trailer at hyway speeds, went I got home and was updocking the trailer, saw spots of oil on my bumper, then noticed how wet the bottom of the diff was.
Originally Posted by Sailor182
(Post 11029026)
Chet:-jammin |
Hey, Already did that, just ready and time to crack it open, front and rear, I just have very little time these days
