limp home
does anyone now what the limp home mode is on a 2007 exp el? The wrench symbol came on the dashboard.
Read owner manual
Powertrain malfunction/reduced
power (RTT) (if equipped): Displays when the vehicle has defaulted to a “limp-home” operation. Report the fault to a dealer at the earliest opportunity. Check 4X4 (RTT) (if equipped): Displays with the message CHECK 4X4 when a four-wheel drive fault is present. When this warning appears have your vehicle serviced by your authorized dealer. Refer to the Driving chapter for more information on four-wheel drive operation. |
Does anyone know what this code actually means or what has actually failed? I had this code come up on my 07 Expedition this morning.
Thanks, Nick |
Been happening to me for a while.. I'm pissed on how Ford has handled the issue. First time it was so called fix was the pedal assembly. Happened again 1 1/2 yrs later the pedal assembly went and needed a new throttle assembly.
