89 f350 start problem
a friend of mine has a 89 f350 with a 460 and it wont start when cranking it with the key.but if the key is on pull it 3 feet and its running what would cause this?
i guess we're all stumped lol
A few possibilities.
Bad/low battery. Loose/dirty battery wire terminals. Loose battery to engine ground wire. Burnt/corroded/bad battery wires. Bad starter motor. |
turns over fine just wont start.unless you pull or push it.
Another possibility is a bad ignition switch (bolted to steering column under the dash).
