Ford Truck Enthusiasts Forums
-   2004 - 2008 F150 (https://www.ford-trucks.com/forums/forum24/)
-   -   auto lamp sensor (https://www.ford-trucks.com/forums/1107873-auto-lamp-sensor.html)
ItsMREMT 10-16-2011 04:40 PM
auto lamp sensor
I have the sensor out of a 2005 F150. There are five wires I would like to know what they are for please and thank you.
http://i393.photobucket.com/albums/p...3/3874ebfb.jpg
shorebird 10-17-2011 07:28 AM
I have scoured my factory wiring manual and I am unable to identify the sensor you picture.
The manual does not show a component with the wires shown in a '04-'08.
I may have missed it.
Are you sure that the object came from a '05?
ItsMREMT 10-17-2011 11:06 AM
yep I stole it from my old truck. It on the dash of all xlts and above it blinks red at night when you get out of it. But most importantly it senses the light if it gets dark the lights turn on.
Coskid 10-17-2011 11:27 AM
That is not what turns the lights on when it gets dark out that is the sensor for the key fob. The sensor that picks up when it gets dark out is up behind the rear view mirror. I have that sensor you are holding on my 2006 on the dash and it blinks red but only when I lock the doors from the key fob.
The sensor you are needing would of had a photocell on it and what you are holding does not. If you still have your old truck then raid it again as that one in your hand should be in your new truck already.
ItsMREMT 10-17-2011 12:44 PM
I'm not sure if I agree 100% with that. Reasons why is 1) I use to put my license plate in the front left window and, I wondered why my lights where always on when I got out. 2) There is a post on another forum where people tape it with dark tape to get daytime running light.
If you have one turn your auto lamps on and cover it with your hand and in a few seconds your lights should turn on.
MCDavis 10-17-2011 01:10 PM
15 seconds or more in fact. Sorry Drew but ItsMREMT is right on this one.
ItsMREMT 10-17-2011 01:32 PM
Thanks Davis! Us Davis folk have to stick together. lol
Coskid 10-17-2011 02:27 PM
OK so I was wrong they used to be behind the mirrors hadn't checked so figured it was still there.
On a side note next time don't send someone a PM that is just piss poor I check back here and always admit when I am wrong about something. If you are right it doesn't require a PM to prove it.
ItsMREMT 10-17-2011 02:43 PM
lol the reason for the pm was cause it was a link that this forum doesn't approve. I tried to post something for there before and it was frowned on so yea.
MCDavis 10-17-2011 02:44 PM
Drew are you serious?
ItsMREMT, if this is true, that's just poor stewardship on your part man. Those kinds of actions won't gain you too many friends around here.
Coskid 10-17-2011 02:51 PM
Yeah its true
ItsMREMT 10-17-2011 03:19 PM
*sigh* if someone can tell me what these wires go to it will be greatly appreciated.
Thanks!
dchamberlain 10-17-2011 04:11 PM
Edit: Sorry, my brain sticks on F-250. I didn't realize this was the F-150 forum.
Give me a bit and I'll see what I can find in the way of diagrams.
ItsMREMT 10-17-2011 04:15 PM
Thank you sir! You are correct, I took this from my 05 F150 Lariat. I would love to figure out how to make this work on my 05 PSD.
dchamberlain 10-17-2011 04:50 PM
2 Attachment(s)
I'm not sure that sun load sensor will work. I've attached two diagrams. The first one is the diagram for a 2004 F-250. The F-250 sun load sensor is 3 wires, one ground, one to the VSM for the auto lamps and one to the EATC if you have it. They are simple photoelectric diodes that either pass current or make current (I'm not sure which) depending on the amount of light they receive.
The second diagram shows 2 of the wires going to the sensor you have. Other wires are power, ground and a wire for the security indicator light. That diagram indicates logic circuitry in the sensor itself that may not make it compatible.
I would hook a DVOM to the two wires shown (white with a violent stripe and black with a light blue stripe). See if their is current on those two wires when the sensor is in the sun vs when it is not in the sun, and see if their is resistance on those wires in the sun vs not in the sun.
