AOD or E40D How do you tell the difference?
Hey guys I have a 92 F-150 that was manufactured in 91. I have been told that some of the early 92's had AOD's before ford made the swap to E40D. Don't know if thats right thats just what I've been told. The reason I'm asking is because I'm thinking about a mass air conversion and it makes a big difference. Any help is appreciated.
Look at the number of pan bolts and shape:
http://www.ricksfreeautorepairadvice...-and-bolts.jpg |
Look at your gear selector.
P R N (D) 2 1 - E4OD (1992+ will have OD cancel switch on column shifter) (1989-1991, OD cancel switch on dash, right side of steering column) P R N (D) D 1 - AOD P R N D 2 1 - C6 Or you can count the pan bolts. 17 pan bolts - C6 14 pan bolts - AOD 20 pan bolts - E4OD |
Easiest way is to climb under and count the pan bolts
http://www.fordification.com/tech/im...-transID08.gif |
Well, if you can't figure it out after the previous posts, there's not much hope for you.
Jason |
Thanks for all the info guys. Unfortunately it's the E40D! Just my luck.
Originally Posted by 92 Red Flareside
(Post 10903288)
If my AOD gives out I can rebuild it for around $600 or less |
(Post 10903288)
My E4OD can be a PITA at times but I will take it any day over my AOD. |
The problem with the E4OD is it shifts WAY to soft! Any tranny that shifts really ssoft like that will never live long.
That's why if I have to have an auto, it MUST be a C6, I will refuse anything else! The hell with OD! |
Originally Posted by IDIDieselJohn
(Post 10903482)
Guy on NLOC had 188k miles on his and it also made 843hp and 936 torque. He had a Punisher valvebody. :-X22 |
Mine lived a long unhappy life (200k miles) being constantly neglected. Take some care of her and she'll take care of you.
Originally Posted by 86F150302
Ive had an AOD and E4OD.
For one, the AOD is rated for 750lb/ft of torque, the E4OD is rated for 1000lb/ft.
(Post 10903482)
Originally Posted by Encho
(Post 10904711)
For one, the AOD is rate for 750lb/ft of torque, the E4OD is rated for 1000lb/ft.
Benefit to the AOD is that it will bolt up to any small block ford, and Lokar sells kits to put the AOD behind a Carburated engine. (If you don't have the carb kickdown bar for the AOD) |
