07 Navigator Suspension Off msg - Plz help
hey guys,
on my 07 Navigator 4x4 ultimate, i see air suspension off msg and the rear of the truck has dropped few inches. can somebody please help me turn this back on, i read somewhere u can turn the suspention back on from the back kick panel but cant seem to find it. please help.. |
Can you access the option through the vehicle message system?
mmm access it how?? i have options and rest button but nothing to turn it back on. may be i am doing it wrong
When you get to that section on your instrument control message center, hit RESET to turn it back on.
Do you have your manual? If not check the Ford site for a copy of the manual here,,, https://owner.ford.com/servlet/Conte...OwnerGuidePage Do you see three buttons on the dash anywhere which shows? INFO - SETUP - RESET From the manual: AIR SUSPENSION SYSTEM (IF EQUIPPED) The air suspension system is designed to improve ride, handling and general vehicle performance during: • Certain road conditions • Steering maneuvers • Braking • Acceleration This system keeps the rear of your vehicle at a constant level by automatically adding air or releasing air from the springs. If you exceed the load limit, the rear air suspension may not operate. The air suspension system will stay active for 40 minutes after the ignition is turned off to accommodate any load changes. (The air compressor may run when the vehicle is off; this is normal.) The air suspension system can be enabled or disabled through the message center. Refer to Message center in the Driver Controls chapter.If the system is off, the rear air suspension will not operate and will not raise (pump) or lower (vent) while the vehicle is not moving. However, if the system determines that the vehicle is low or high and needs to make a height adjustment while driving at speeds above 15 mph (24 km/h), the system will pump or vent as required. Normal vehicle operation does not require any action by the driver. On vehicles equipped with air suspension, turn the air suspension and the ignition switch off prior to jacking, hoisting or towing your vehicle. 2007 Expedition (exd) Owners Guide (post-2002-fmt) USA (fus) Driving 263 |
Also from the manual:
Air Suspension Before disabling the air suspension, make sure the liftgate and liftgate glass are in the closed position. 1. To disable/enable the air suspension feature with the vehicle in P (Park), select this function from the SETUP control for the current display mode.[/LEFT][/LEFT] 2. Press the RESET control to turn the air suspension OFF or ON. |
hey bro, i have three buttons INFO SETUP REST
i followed your instructions and the air suspension was turned off, so first i hit setup button till i got to air suspension menu , it was off so i hit reset and the brackets came over to ON. it says air suspension on when i do the system check, but my navi is still dropped from the back :( you think something might have gone wrong with the suspention? |
Hmmm don't know about that, is it give you any codes? With the air system ON, if there is a problem with it, you probably will get a warning light.
The driver manual may help to determine whether there are issues with the nav system. Explain about your navi "is still dropped from the back"? |
nop no warrnings, or error codes, and navi is so dropped that i cannot even drive it.
Originally Posted by mginc
(Post 10901878)
After you changed the setting did you start your truck? This should turn on the air compressor I do believe. If not, then you need a dealer to look at this for you. |
i mean the navigator is so much dropped, that if i drive, it feels like i am hitting the tires.
Can you hear the air compressor come on?
If not, then check for blown fuses for the compressor. If you cannot find then a trip to the dealer is in order. |
nop, cannot hear compressor, bro could you tell me where to look for these fuses? under the hood?
Do you have the owners manual?
See pages 288 to 295 |
i found this on page 261 in the online owners manual http://content.screencast.com/users/...6/00000760.png
just need to figure out where this box is located. |
