1966 Ford F100 Interior Trim Code
Hi -
I'm looking at a 1966 Ford F100 short box pick-up and it appears to have a letter "V" on the VIN tag for the Interior Trim Code. This letter "V" is just to the left of the "81" body code for a conventional cab. My shop manual does not list a "V" interior trim code. Does anybody know what the "V" code means? Thanks, Dan M. |
Originally Posted by Mercmeister
(Post 10894629)
Hi -
Dan,
As you know, in '66, the trim code is on the Warranty Data Plate (WDP), which is mounted on the driver's door. A WDP with a V81 trim code indicates that the truck that was originally outfitted with THAT DOOR was ordered from FoMoCo with the much-sought RANGER trim package! So the next question is: Is the door original to the rest of the truck or was the door replaced/changed sometime in the past 40+ years??? Realize too, that some folks will PAY GOOD $$ just to have that tag and/or door... Sooooooo -- if the truck is total junk or even if just the door is total junk, then a person should try to saw out a sizable portion of the door - around that WDP - before it is sent to the crusher........... BarnieTrk :-X0A6 |
Thanks Guys,
The truck that I'm looking at currently has a bench seat installed. I am assuming that over the past 45 years, the bucket seats may have been removed for a "more convenient" bench seat. Is there any way to check from underneath the truck to verify that the truck was originally provided with bucket seats? Are there any other tell tale signs to verify the truck is a factory Ranger? Thanks, Dan M. |
Dan,
Off the top of my head, I can't help ya. I suggest you do a topic search as to how to tell if it's a real RANGER or not. There are a BUNCH of threads on the ID of Rangers....... BarnieTrk :-X0A6 |
If it had bucket seats it should have four stock looking mounting holes on each side for the seat mounts
(Post 10898752)
Thanks Guys,
Originally Posted by BarnieTrk
(Post 10898518)
Dan,
Realize too, that some folks will PAY GOOD $$ just to have that tag and/or door... BarnieTrk :-X0A6 There are no records or any numbers matching. I can recreate a ranger and you or anyone else would not be able to tell if it is real or fake. There are more rangers on the road today then were ever produced. Garbz |
I also wondered what good a tag would be. Wouldn't it still have to match the #'s on the frame of what ever you put it on?
Are the brackets that hold the carpet on look anything like the ones that hold the plastic tank covers on? |
