Ford Truck Enthusiasts Forums
-   1987 - 1996 F150 & Larger F-Series Trucks (https://www.ford-trucks.com/forums/forum28/)
-   -   What is this sensor? (https://www.ford-trucks.com/forums/1105087-what-is-this-sensor.html)
Blue86 10-05-2011 10:14 PM
The engine is a 1992 4.9L. I'm putting it into my '86 F150. I haven't found the map sensor harness yet so I was leaning towards that.
http://img.photobucket.com/albums/v3...t/914bf61b.jpg
SideWinder4.9l 10-05-2011 10:59 PM
You know, I have that same connector lying around willy nilly too....Not hooked up..Just lying there...
Btw...The Map sensor has a vac/ line to it...
Edgethis 10-05-2011 11:01 PM
That's for the flux capacitor.
Actually I have no idea, but i wanted to bump to the top for more helpful people.
kd0axs 10-05-2011 11:13 PM
It's been a while since I had a 300 apart, but I seem to remember that harness running down between the intake runners to something under the manifold. Can't remember exactly what though.
SideWinder4.9l 10-05-2011 11:20 PM
I honestly have no idea either...So I simply laid it off, that if 2 300's had it, and wasn't plugged up...It was a spare connector, or it was for something the truck didn't come with....:(
Blue86 10-05-2011 11:20 PM
Hahaha! Thanks.
Encho 10-05-2011 11:50 PM
It's probably a plug to retrieve data and diagnose the injectors, not a sensor (just a guess, but it does look like that).
Blue86 10-06-2011 12:05 AM
You're thinking about the EEC connector. That's mounted on the firewall near the master cylinder.
SideWinder4.9l 10-06-2011 12:23 AM
I'm sure Encho knew that...But I also think he may be onto something...Considering that, the injectors are the ONLY electrical things within reach of that connector...Maybe some sort of secondary diagnostic tool...
EPNCSU2006 10-06-2011 05:55 AM
I think that is for the canister purge valve. The valve is located in the vacuum line between the throttle body and the carbon canister and will sit near that plug on top of the lower intake manifold runners.
jplinville 10-06-2011 06:56 AM
As stated above, that's for the optional Flux Capacitor. There were only 3 trucks that left the factory with this option installed. You happen to be the proud owner of one of those 3.
You'll have to build a new Flux Capacitor, since Doc Brown is stuck in a different, alternative time period and is unable to help.
But today is your lucky day!! I located a DiY Flux Capacitor instructional web page. You'll have to upgrade the nuclear device located above the spare tire mount to accept garbage to make it work...but I'm sure you have the intelligence to do it. DIY Flux Capacitor
If you are able to make it work, go back to 5/7/1993 and force me to leave with you and talk some sense into me...I don't want to make the mistake of marrying that psycho woman.
subford 10-06-2011 07:11 AM
That should be the plug for the fuel rail cooling fan to prevent vapor locking on the 4.9L engine.
kd0axs 10-06-2011 08:31 AM
I forgot about this. Neither my 93 or 95 300s had this. IIRC, on the newer models, they got rid of the fan and raised the fuel pressure to prevent vapor lock. I'm thinking this means that he is also going to need the newer fuel pump for the 92 engine to run properly in his 86 truck.
EPNCSU2006 10-06-2011 06:31 PM
There's not a fuel rail cooling fan on a '92. I'm reasonably certain that connector fits the canister purge valve - only reason I'm not 100% is I haven't had a look under the hood of my dad's truck in a while (also a '92 w/ the 300).
subford 10-06-2011 10:17 PM
Is the plug from the 86 or the 92 engine harness?
© 2018 MH Sub I, LLC dba Internet Brands
