Battery Power Drain
1996 F250 PSD 7.3L Automatic transmission has a power drain issue. Went to go start the truck. All it does is click. In order to now start it, It gets jumped by my Dodge Ram 1500 5.2L Any thaughts here? :-huh
Some times it couldbe the battery. Particals can settle in the bottom of a cell and short the plates. This will cause a voltage drain in the system. If you know the battery is ok you can use a volt meter and remove fuses to pin point the short in your ele.system. A multimeter is very handy I use mine all the time in the shop and around the house.
I hope this helps. If you need more TS details let me know. I have been a heavy equipment mechanic for 30 years and I only own FORDS :-) |
I should have mentioned that the batteries are both new.
Is your glow plug relay stuck closed? I have heard this is a rather common problem with the PSD.
How do I check that? The GPR was replaced last year.
I used these to find my battery drain
How to Find and Stop Car Battery Drains DIY Car Battery Drain - Popular Mechanics Diagnosing A Car Battery That Runs Down[/URL The only thing I would do differently is to start by disconnecting the entire PDC before pulling fuses. My drain was a bad alternator, so alot of time could have been saved if I had eliminated all circuts at once. |
What is PDC?
nice link brian. that is much better than trying to type it all. I cant type for crap GJ.
