Problems with Engine!? 1951 F1, 226 cui
hi
i own a 1951 F1 Pickup 226 cui GVWR: 4700 lbs engine #: 7HA6050-C2 and i think i have a problem with the engine What is wrong with the engine if fluid (i think fuel) comes out of the hose at the pic? For what is this hose? Many thanks in advance! best regards from austria passenger side under the intake manifold: http://i51.tinypic.com/t8l1c9.jpg |
What you have there is the precursor to the PCV valve. The pipe coming off the side cover is called a "road draft tube" which equalized the pressure inside the engine. For more info try this post:
https://www.ford-trucks.com/forums/1...-i6-226-a.html |
bacagrizz,
thanks for the link! I have read the linked post. Unfortunately I am still not clear what's wrong, if fluid comes out of the hose. I hope you can explain that in more detail. Following the diagram from the engine: http://i56.tinypic.com/29c1254.jpg |
Is the "fluid" more than the amount of condensation you would expect on start-up? Is it an actual flow of water? If so, you have a cracked block and water jacket coolant is leaking into the valve chest. Is the fluid green like antifreeze? If it's a cracked block, it will leak out of there whether it's running or not.
If it's just a drip-drip-drip of clear water when running, you need to warm up the engine thoroughly to evaporate water in the crankcase, and probably change the oil. |
On last sunday we had the following situation:
After a halt of about 6 weeks we have started the truck again. Then, for about an hour, fluid (about 0,4 gal) came out of the hose. not in idle, only on accelerate. The liquid smelled like gasoline. Maybe mixed with some oil. But we are not really believe that even cooling liquid was present because in the radiator was nothing less:-huh Damn - I really have no idea what that is. It's also not possible that so much gasoline flows through the engine, right? In the meantime, we drove about 150 miles with the truck without liquid coming from the hose. Only some smoke on the first 60 miles. Then this stopped also. The engine is not getting hot and on the day after no oil or other liquids was on the floor.:-X22 Please forgive me my bad English. Kind Regards, Daniel |
Check the oil; does it smell like gas? I suspect your fuel pump diaphragm is ruptured and gas is getting into the crankcase. The fumes will condense in the valve chest. Needs to be fixed ASAP!
Originally Posted by ALBUQ F-1
(Post 10856888)
:-drink
daniel |
Indeed...ALBUQ F-1 is giving you good advice. If the fuel pump diaphram is broken, gasoline can go into the crankcase. Initially it will dilute the oil, but it will quickly evaporate and the fumes will go out of the road draft tube. If it was cool out and you were just warming up the engine, the fumes could condense and show up as a liquid. Later on when everything was warmed up it would just go out as a vapor. You probably would notice that your gas mileage is a little worse than normal. The oil level may also appear to be a little high.
And...welcome from California. Maybe you could send us another Austrian governor for our state!! Dan |
People of Kahlifoneeah!
Originally Posted by old_dan
(Post 10858090)
And...welcome from California. Maybe you could send us another Austrian governor for our state!! Dan Oh, and we have to offer no more Hollywood stars to.;) Daniel |
Originally Posted by 51PanelMan
(Post 10858320)
My other two favorites are: "Who iz yoh dahdee and what dahs he dooh?" and "I'm a kop, you eedeeot!" Both are from the greatest movie of his career, Kindergarten Cop.
