How do I test PCM
I have a 2001 Exp giving a P0352 code. plug good,COP good. Hodo I test PCM?
For which cylinder did you test the plug and COP?
#2 which was the indicated bad cylinder with the P0352 error code
Just checking, I wasn't intending to insult. You'd be surprise at how many people get the wrong cylinder. Now back to my question, sorry I wasn't specific. What I was really looking for is the physical location of the cylinder you checked. As in which side and how far back from the front. The #2 is the second one back on the passenger side. Is that the one you checked?
Didnt mean to be a smart ass. Im relatively new to working on engines and just wanted to give good info. I checked the 2nd cylinder back on the passenger side. COP is good and new plug. there is a problem with the connector coming off harness in that the clip mechanism is broken so connector is not locked in.However when I manually held connection tight while the engine was running no improvement was apparent with rough idle.
Originally Posted by Shambelous
(Post 10849524)
Ive got a 1999 crown vic. Can I clip connector of it and sodder to faulty clip on Exp
If the clip fits, wear it! :)
How is the clip on the #2 injector? Is it on and tight? Be careful when working arount the COPs as they put out a very healthy jolt.
