Fuel water separator draining
I am new to diesels as far as ownership. How often should I be draining my water separator. I have no indicator lights. Saw ricks trouble with possible warranty denial due to water in fuel so wanted to check and see. Only have 1100 miles and 3 fillups.
It's recommended that you drain the fuel/water separator once a month to remove contaminants. See page 67 of your diesel supplement! :-X22
It is always a good practice to get into a preventive maintenance routine with these trucks. I go back to my old Army days where there was a specific routine for each piece of equipment before it was operated. I do the same with this truck and my farm equipment. Everyone is different and has their own way of doing things. At minimum, I recommend you follow the manual for the different maintenance tasks.
I drain mine monthly.
The low cost of lost diesel is much cheaper than a new fuel system. |
Doesn't the computer let you know when it needs drained?
Originally Posted by GCLL
(Post 10823209)
Glad I ran across this thread. Had the truck for 7 months and have never drained it didn't know it needed to be done so often and still wouldn't if I hadn't read this. Hopefully no damage has been done. Is it easy to do?
Originally Posted by F2502011
(Post 10825192)
This is good info, guess I need to drain mine. I assume that using a fuel additive like the motorcraft brand will help reduce the water.
(Post 10823209)
Ie; stop now and figure out why if it does turn on. I've never had any water in my fuel but I wouldn't know that if I didn't drain it. |
Anyone know if draining water from the fuel separator is standard practice for a dealer while performing an oil change/service.
I drained my separator for the first time. I drained it for about 25 seconds as recommendeds by the supplement. I really did not see any water (I don't think). The fluid must have been diesel fuel. How do you tell the difference between water and diesel fuel??? If I continued to drain the separator, will the fluid finally stop, or will it continue to drain diesel?
The diesel fuel is very pungent. Before my wife let me into the 5th wheel I had to change my closes and wash up. ken |
Originally Posted by wtrlogd
(Post 10825876)
My truck gets drained every other tankful. Regards |
Originally Posted by kabur66
(Post 10825957)
Just drained mine about an hour ago...no water that I can see. Kinda makes one nervous though if we get bad fuel from a filling station.
