How to take apart a 8.8" 3.55 axle????
First time tearing into this. The passenger side seal blew and the outer wheel bearing burned up. Now I can grab the flange and wiggle it with 3/8" of slack.
Haven't opened it up yet but wanted to get some pointers. Is it the usual C clip affair? Do I need to remove the backing plate? etc? Any pics or anything would greatly help :o Specs: 8.8" ring gear 3.55 ratio Open diff Drum brakes Comes off 4.2L 2000 F-150 XL supercab |
C clip, but not sure about backing plate.
This is interesting: http://www.explorer4x4.com/axleseals.html More: http://www.pirate4x4.com/forum/showthread.php?t=806448 |
Thanks so much!!!!! :)
Yes, you have to remove the backing plate. Once you do, there will be a small bolt holding the crosspin in place. Be extremely careful with this bolt. It's very common for it to snap off and then you are in a world of hurt. Once you remove it, the crosspin will come right out and then both axles can be pushed inward to expose the c-clip. The clip comes out and the axle will slide right out.
"Backing plate". Yes, the cover comes off the back of the differential.
I think the OP was talking about the brake backing plate at the wheel. Not sure you have to pull that. |
Yes I meant the brake backing plate. Thanks!!!! :)
