shuts off while driving
having problem with engine shutting off while driving will restart with easy moter does not skip or make any kind of noise
Check for fuse/relay seating issue on both fuse panels (under dash and in engine bay).
Then the plug on the crank sensor. If it starts again after a stall, it may be a temperature or vibration sensitive issue. Good luck. |
look on the passenger side of the motor , i had a wiring harness that would touch the exhaust maniford at times and kill the motor.... the harness fell out of it holder .... it started blowing the maxi iginion fuse... hope this helps:)
