6.0 Oil Temp
Can anybody tell me what the normal operating oil temp is? I read somewhere on this forum that anything over 150 degrees is bad. My operating temp on a 85 degree day doing normal driving is about 185 degrees. I got that reading off my bully dog. Not sure how accurate it is. Before any comments come thundering down about the bully dog, I switched to the SCT Livewire today. Much better choice. Only question about the Livewire is....When I installed and took it for a test drive, at WOT, it seemed to hesitate a little. Not sure what that was. Almost like it wasnt getting enough air.
Originally Posted by amdriven2liv
(Post 10761392)
If your temp on ECT is that low, Your "T" stat may not be working properly, might think about changing it. Your ECT should be at 190 and up. The stock T-stat is designed to fail "open".
And "Bully" for you on changing to SCT! |
I have a 06 6.0 wondering if my oil/coolant temps are too high I live in Alberta n today's temp was 28 degrees n when the truck is fully warmed up the terms are in the low 90,s when driving coolant hits 96 oil is +- 4 is this average I am getting these readings from my sct, anything on it would be great thanks.
6.0 Oil Temp
Do you mean 190's or actually 90 something degrees. And are you talking °F or °C
Originally Posted by 6.ooh
(Post 15494757)
If you are talking Celsius that would be 194* to 204* with oil temp being with in 4* and if the 28* which would be about 82*, that all sounds good to me. :-jammin:-drink :-X25 |
Yea I mean Celsius, n thanks 2006white60
